What is the part number and where can I get the proximity sensor on the PSoC 6 BLE Pioneer kit? It doesn't show in the BOM. The location designator is J13 and it is a two pin device. I wish to use it in a design. Thanks.
Hi Andrew,
CapSense proximity sensor is a simple wire loop connected to J13 as the following images show:
You don't need to populate any other parts for the proximity sensor to work since it uses self capacitance based CapSense which requires just 1 sensor. Please see the following code example for details:
http://www.cypress.com/ce218137
Nidhin
part number: CY8CKIT-062-BLE PSoC6 BLE Pioneer Kit.
Device number: CY8C6247BZI-D54
Proximity sensor: P8.0
Proximity sensor: About the layout, you can refer to the link document: http://www.cypress.com/file/46741/download
In addition, J13 only one pin loop~
Hi Andrew,
Nidhin
