Dear all:
I am facing a question while using ADC. The CY8CKIT-062-BLE just has only one ADC chip,but what's the point that I can add countless ADC components? I want to implement switching in three sampling modes:channel A or channel B sampling alone and channel AB sampling successively.It would be better if AB could sample at the same time.I am so confused to implement this.
Looking foward to your reply.
Hello Peng,
Please see the ADC component PDL documentation (file:/C:/Program%20Files%20(x86)/Cypress/PDL/3.1.0/doc/pdl_api_reference_manual/html/group__group__s... ). All the ADC settings and configurations are handled there. To configure the SAR subsystem, call Cy_SAR_Init. Pass in a pointer to the SAR_Type structure for the base hardware register address and pass in the configuration structure, cy_stc_sar_config_t. After initialization, call Cy_SAR_Enable to enable the hardware.
You can generate code for multiple configurations and initialize ADC with each of those configurations. As you know you cannot use it simultaneously but can be used in a time shared basis.
Vasanth
Hello Peng,
Vasanth
