I wanted to learn more about using the RTC component, so decided to download two of the code examples "RTC Basics" and "CE220186 RTC CTS".
However, when I click on the "generate application" button with either example, it throws up this error:
Clock Error: (Clock must be enabled. Hardware does not support disable.).
Error location: Clk_PumpPeri
Type: Design-wide
I'm looking for advice on how to fix.
Thanks for the feedback.
Yes, this was a strange one alright. I eventually resolved by simply clicking on the clock in question (within Design Wide Resources) and clicking OK. That was it!
I compiled the program on my system using PSOC Creator 4.2 and it worked as expected. You have to use an IPhone for this program to work, Also have you read this http://www.cypress.com/file/390496/download and have you read the PDF in the Program files for this program.
Here is the PDF http://www.cypress.com/file/385906/download
Generate Application runs okay also. Have you made any changes to the program and if so Please send your program by clicking on File and then Create_WorkSpace_Bundle and attach the zip file to a new Comment.
