I plan on buying the PSoC 6 WiFi-BT pioneer kit and wanted to create a 3D printed enclosure to physically attach the board to my project. What documentation would have the physical dimensions of the pioneer kit?
- psoc 6 wifi-bt kit
If you have installed the kit support package: Download CY8CKIT-062-BLE PSoC 6 BLE Pioneer Kit Only Package (Kit Design Files, Documentation, Examp...
You can find the fabrication drawing with dimensions of the board (default path: C:\Program Files (x86)\Cypress\CY8CKIT-062-BLE PSoC 6 BLE Pioneer Kit\1.0\Hardware\CY8CKIT-062-BLE). Unfortunately the drawing is without hight of the components.
If you want to add cutouts for external connections. I think the easiest way to get the component position is through the gerber files.
Also important: On the bottom of the board there are four 8mm rubber feet.
kind regards,
Achim
kind regards,
Achim
Thank you. That was what I was looking for. Only thing I'm missing now is the height.
Hi Cody,
Height will not be same in all area of the kit. It varies with respect to components mounted on the place holder. I think you may get better idea by cross verifying the components vs its data sheet information.
Also take into account the 8mm rubber feet that are placed in the four corners of the kit at the bottom.
Bragadeesh.
Bragadeesh
