PSoC™ 6 Forum Discussions
EdHa_4455331
25 replies posted 25 sign-ins 10 replies posted
I am about half way through a project and I would like to see how much RAM and FLASH (for code) has been used up. In most other IDEs I can find this information in the map file produced by the linker. But so far I haven't been able to find this in the map file created by Creator 4.3 or anywhere else in the reports, tabs, etc. that are available.
Can anyone point out to me where I can find this information?
Ed H.
Len_CONSULTRON
Level 9
Level 9
500 solutions authored 1000 replies posted 750 replies posted
Ed,
If you are able to successfully build the project as it currently stands, then do the following:
  • Perform a "Clean and Build".
  • The Output window should report NO errors preventing the build and the bottom of the output window should list:
code:412168    sram:35748
--------------- Build Succeeded: 04/29/2020 22:18:08 ---------------
code: = FLASH allocated and sram = RAM used.
Is this what you are looking for?
Len
Len
Len_CONSULTRON
Level 9
Level 9
Ed,
Len
Len
Yep! Sure enough, there it is. 🙂
