PSoC™ 6 Forum Discussions
bahlemeyer
How do I use a Pemicro Multilink Universal debug module in ModusToolbox3?  I have the GDB Pemicro server installed on my computer because I use it with NXP Kinetis Design Studio.  When I try to create a debug configuration in ModusToolbox 3 that selection is not in the list.
LeoMathews
100 sign-ins 25 solutions authored 100 replies posted
Hi @bahlemeyer
Kindly note that you won't be able to program using Multilink from ModusToolBox3.0. As a workaround, you can port your ModusToolBox project to another supported IDE like Keil uvision and then use a Pemicro Multilink Universal debug module with Keil.
Thanks and Regards,
Leo
LeoMathews
Hi @bahlemeyer
Thanks and Regards,
Leo
Thanks, Leo.  Do you know the reason that it is not supported?  I see on the Pemicro site that it can be used with the DAVE IDE, but I don't think that I can use that with my CY8C6144LQI-S4F12.  Can my CY8CKIT-062S4 be used without removing the uC on that board?  What would you suggest?  The Miniprog4 or would a J-Link be better?
