yangyong
50 questions asked 50 replies posted 100 sign-ins
I update CC0_BUFF, The output waveform is as follows. What is the appropriate reason? thanks!
DennisS_46
100 sign-ins 50 likes received 50 solutions authored
The period of the PWM appears to be the same before and after the pulse width change. The pulse width change (register write) is not synchronous with the pulse width (compare value).
---- Dennis Seguine, PSoC Applications
Yugandhar
1000 replies posted 5 likes given First comment on blog
Could you please refer to the mtb-example-psoc6-pwm-dual-compare-capture  code example from the MTB ? If you are still facing the issue then please share your project for debugging at our end.
P Yugandhar.
DennisS_46
