Good afternoon
I have the question about PSoc 63 microcontroller, specifically about the "Table 8. Multiple Alternate Functions". ACT #7 from https://www.infineon.com/dgdl/
PSoC 6 MCU
Hi @rod18069,
P6.4 and P6.5 use SCB 6 whereas P9.0 and P9.1 use SCB 2 and thus you cannot use the same SCB using these 2 sets of pins. However, if you check P7.0, P7.1, and P8.0, P8.1, both use SCB 4. In this case, you can assign either P7 or P8 for SCB 4 -
Rakshith M B
Hi @rod18069,
Rakshith M B
