Hi, Yuzh and Rakshith,
In replies in the other post (https://community.infineon.com/t5/PSoC-6/PSoC64-Inquiry-of-time-from-device-reset-to-user-applicatio...), you've informed the secure boot time of PSoC6.
Then, I want to measure it in my side with CY8CPROTO-064B0S3. Could you guide me how to measure?
ispn:40051:1:0
l1:314:1:0
Hi @pagansjb,
For our internal testing, the secure CM0+ image was modified to ensure that we catch the completion of all three stages - flash boot, bootloader, and CM0+ secure image. Unfortunately, as you will not be able to modify the CM0+ image, you will not be able to measure these parameters at your end. However, you can still measure the time from POR to CM4 image which will be approximately the time the device takes to hand over the control to the user application.
Rakshith M B
Hi @pagansjb,
Rakshith M B
Hi @Rakshith
Thanks for your response.
I have another question. Is there any meaningful difference in terms of secure boot time if re-provisioning is enabled or not?
pagansjb
Hi @pagansjb,
Re-provisioning should not cause any significant changes in the boot times. I will confirm this internally and get back to you.
Rakshith M B
