PSoC™ 6 Forum Discussions
SuSh_1535366
50 questions asked 50 replies posted 50 sign-ins
I want to know the CPU current of the PSoC61 series, but the datasheet only has information about dual-core device (why?).
Please tell me the CPU current specifications for single-core products.
Shimamura
Rakshith
Hi @SuSh_1535366
In PSoC 61 devices, the CM0+ exists and is reserved for system functions like flash write, eFuse read/write, etc. It is not available for application programming. This is why the datasheet contains information regarding the CM0+ CPU.
You can also find this information in the datasheet -
Thanks and Regards,
Rakshith M B
Rakshith
Hi @SuSh_1535366
Thanks and Regards,
Rakshith M B
SuSh_1535366
Hello Rakshith,
I overlooked the relevant part of the datasheet.
I see that the CM0+ core was also included in PSoC61.
What is the operating mode of CM0+ when PSoC61 is running?
Active, Sleep, or Disable?
Does the CM0+ operating mode have to be controlled from CM4?
Shimamura
Rakshith
Hi Shimamura-san,
I apologize for the delay in my response.
The CM0+ CPU will be in deep sleep mode.
No,  whenever there is a system call that needs to be handled, the CM0+ will be woken up by events/interrupts and it goes back to deep sleep after completion.
Thanks and Regards,
Rakshith M B
SuSh_1535366
Hi Rakshith,
Thank you for your answer.
Shimamura
