Rolf_Nooteboom
10 sign-ins 5 solutions authored First solution authored
Added the UDB PWM block for PSoC6 which provides PWM routing to every IO.
UDB's rock, don't let the magic die!
GitHub - onethinx/UDB-Components: PSoC6 UDB Components
Ekta_N
750 replies posted First like given 250 solutions authored
Hello RoNo_264271
Thank you for adding the UDB based PWM component.
I was successfully able to use the PWM component added by you in my PSoc 6 project.
Thanks and Regards
Ekta
