PSoC™ 6 Forum Discussions
JiaweiL_16
25 sign-ins 5 replies posted 5 questions asked
I don't find any spec about the SIMO Buck in datasheet Electrical Specifications, TRM or AN218241.
Only thing I can get is the MPN of the Inductor in EVK.
I think I must miss some portion about this component inside PSoC6. It does not make any sense to unknow the SIMO buck spec about the Power system of PSoC6, it impacts engineer to select inductor or capacitor for the PSoC6 SIMO Buck external. There is no idea about the efficiency,buck drive frequency to valuate the performance.
Please tell me where I can find this spec?
Ray
Vasanth
Hi Ray,
As of now there is no characterized data to be shared on this. So unfortunately there is no spec which provide the graph between efficiency and these values. Nevertheless the MPN and the value suggested will help you to get the guaranteed performance in the datasheet. Anyways I will pass this suggestion and will try to see whether this can be accommodated in the future versions of the documentations.
Vasanth
Vasanth
Hi Ray,
Vasanth
Vasanth,
Ray
