Hello Community,
I am observing a strange build problem with MCUBoot Roll back code example with ModusToolbox 2.4;
I initially tried this example on MTB2.3.1 and everything works perfectly fine. But, when I started using this CE in MTB2.4, it throws a strange linker error.
"arm-none-gnueabi/bin/ld.exe: Cannot find : Invalid Arugument"
Collect.exe: error: ld returned 1 exit status
Is this a known issue or something is wrong with my build setup ?
Thanks in Advance,
Stephan C
This is a known problem with MCUboot Rollback Code example due to a typo; The root cause is the blinky_cm4 application Makefile, extra comma after Wl,-defsym argument.
Remove "," from LIne 198 of this file.
https://github.com/Infineon/mtb-example-anycloud-mcuboot-rollback/blob/master/blinky_cm4/Makefile
defsym=CM0P_FLASH_SIZE=$(BOOTLOADER_APP_FLASH_SIZE), --> change to --> defsym=CM0P_FLASH_SIZE=$(BOOTLOADER_APP_FLASH_SIZE)
Root cause of the issue is - MTb2.4 uses GCC-10.3.1 + LD 2.36.1, where defsym argument parsing has changed compare to earlier GCC 9.3.1 + LD 2.34.0 (MTB 2.3);
