CaKu_4284131
50 replies posted 25 replies posted 10 likes received
When I program my CY8CKIT-062-BLE I get this warning:
Programming device 'PSoC 63 CY8C6347BZI-BLD53 (CM4)' with file 'C:\Users\carlk\Documents\PSoC Creator\PSoC 6 intro\CapSense_BLE.cydsn\CortexM4\ARM_GCC_541\Debug\CapSense_BLE.hex'.
Device ID Check
Warning: The connected PSoC6 MCU device is out of date. Please contact Cypress to get a replacement
How can I fix that? Might it have anything to do with BLE difficulties I've been having?
This warning is displayed for kits w/ PSoC6A-BLE Silicon Revision (Rev.*B) and FlashBoot build version less than 29 because in this combination of Silicon and Flashboot, the build is broken and might cause numerous issues. Request you to update to the latest revision.
You will contacted by Cypress to provide you a replacement.
Dheeraj
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Beta tester First comment on KBA 1000 replies posted
I'm on Kit rev *D, Board rev 13. Is that already out of date?
MotooTanaka
Level 9
Level 9
I often heard this problem from board rev ~ *B.
So I'm surprised that you have this problem with rev. *D.
As the message states, you may need to contact Cypress about this problem.
I would suggest you note both the revision and the marking on the device of your board to inform Cypress.
On the other hand, with this warning message, my colleague could program the device and debug it with his program, I'm not sure if it had BLE function though.
So it may not be the root cause of your problem.
But to be on the safe side, I would suggest you acquire a board which could be programmed without this warning.
moto
I tried contacting Cypress via email, and they directed me here.
MotooTanaka
Level 9
Level 9
Unfortunately, I'm not "Cypress" and it is the weekend now.
Let's hope someone from Cypress will contact/inform you about what to do with your problem.
I'm sorry for not being helpful.
moto
P.S. I lived in Colorado Springs, I loved living there 😉
Thanks anyway, moto.
On Sat, Feb 8, 2020, 5:34 PM Motoo Tanaka <community-manager@cypress.com>
Dheeraj
Some more info. from PSoC Programmer:
Installed CyInstaller Products:
Bridge Control Panel  1.20.0.4409
Clock Programmer  1.9.0.4409
Device Database  4409
Example Code  4409
PSoC Programmer  3.28.6.4409
USB Bootloader Application  4409
  Automatically Detected Device: CY8C6347BZI-BLD53
Silicon: 0xE207, Family: 0x100, Rev.: 0x22 (*B)
SROM Firmware: 2.01, Flash Boot: 1.0.1.20 (*B)
Protection state: 0x02 (NORMAL), Life Cycle stage: 0x01 (NORMAL)
KitProg3. CMSIS-DAP Version 2.0.0. Firmware Version 1.01.158. Hardware Id 02.
