Is there an example code of PSoC6 I2C master using DMA?
My development environment is as follows.
- Modus Toolbox
- CY8CKIT-062-WiFi-BT
Thanks and Regards,
YS
It does not look like there is. You could get the DMA example from the UART one though.
https://github.com/Infineon/mtb-example-psoc6-uart-transmit-receive-dma
FYI, this is kind of the master example list.
https://github.com/orgs/Infineon/repositories?q=mtb-example-psoc6+NOT+Deprecated&type=all
