Mar 19, 2019
07:10 AM
Mar 19, 2019
07:10 AM
I'm getting angry about PSoC6 (CY8C6347BZI-BLD53). I try to perform a Boundary Scan (Goepel) on our prototypes and I only get errors from the insruction and data register. The JTAG signals looks great, the test-byte is shifted out again onto TDO but it looks like the BSDL File is build for the IOSS TAP and not for the CPUSS DAP TAP ???
Does someone have an idea?
Labels
05:39 AM
Mar 22, 2019
05:39 AM
Can you please attach the BSDL files you are using? It will give information on your JTAG debug configuration as well as more insight into your issue.
Also, if you have any screenshots you can share of the error, it will be helpful.
Dheeraj
