- Email to a Friend
I am trying to generate a carrier wave using TXC command on CY8C6347FMI-BLD53T. However, it shows exact the same oscillation freq peak as when I generates modulated "0" signal using TXM command.
Is this working properly? If not, how can we solve this. It would be appreciated if someone could provide us solution or similar threads.
Thank you.
[Edit]
more specifically, we get as follows:
TXC 0 0 1000 >> peak frequency of 2401.854MHz
TXM 0 0 1000 >> peak frequency of 2401.854MHz.
- Email to a Friend
Yes, with TXM command with payload type 0, it transmits at centre frequency. What you observed is only carrier wave and not modulated 0 with TXM command with payload 0. TXM command is added for use with PRBS payload(SPT 0) for regulatory emission tests only.
P Yugandhar.
- Email to a Friend
P Yugandhar.
- Email to a Friend
Thanks alot @Yugandhar for your kind support.
I am totally convinced😁
