I'm using CY8cPROTO-063-BLE PSoC 6 BLE PROTOTYPING KIT with CYBLE-416065-0243-SMT which sends and receives some values over BLE from an APP Cysmart.
The device is configured as follows:
GAP role: Peripheral
Type of advertising:
Filter Policy: Scan Request: Any | Connect Request Any
Map of advertising channels: All channels
Fast advertising interval
Minimum (ms) 20
Maximum (ms): 30
Check Timeout (s): 30
Security Mode: Mode 1
Security level: Authenticated pairing with encryption
Encryption key size (bytes): 1
The device connects correctly with the app and the pairing procedure works correctly. At the end of the connection the bonding is saved correctly.
But if the device subsequently establishes a another connection always with the same smartphone, with the CySmart app, the smartphone's operating system requests the pairing password again even if the bonding procedure was previously successful.
How I can risolve this problem ?
Thanks in advance for any replies.
Lucia
PSoC 6 MCU
- ble
- PSoC 6 MCU BLE
Hi @l_diserio
Please can you go through this below link for fixed passkey issue.
https://community.infineon.com/t5/PSoC-6/PSoC6-BLE-setting-a-fixed-pass-key/td-p/224958
Thanks & Regards
Pratiksha V
Hi @l_diserio
I hope before you store the bonding data, you need to check a variable "cy_ble_pendingFlashWrite". Only when this variable is non-zero, you should call "Cy_BLE_StoreBondingData()" API. You cannot store bonding data if this variable is 0. Hence in your main code, after you call the Cy_BLE_ProcessEvents, you can check if the variable is non-zero or not. If it is non-zero, you can call the "Cy_BLE_StoreBondingData()" API.
if this doesn't work please can you share your code so that we can check at our end.
Thanks & Regards
Pratiksha V
Hi @PratikshaV .
thanks for your reply.
I check "cy_ble_pendingFlashWrite", after Cy_BLE_ProcessEvents, and only when this variable is non-zero, I call "Cy_BLE_StoreBondingData()" API.
But this doesn't work. I share my code .
Lucia
Hi @l_diserio
I tried to build your shared code but unfortunately I was not able to build it successfully please can you check the attached code example.
Thanks & Regards
Pratiksha V
Hi @PratikshaV
Your code works! But I need to set a fixed passkey. I have add the following code in the case CY_BLE_EVT_GATT_CONNECT_IND
case CY_BLE_EVT_GATT_CONNECT_IND:
appConnHandle = *(cy_stc_ble_conn_handle_t *)eventParam;
DBG_PRINTF("CY_BLE_EVT_GATT_CONNECT_IND: %x, %x \r\n",
(*(cy_stc_ble_conn_handle_t *)eventParam).attId,
(*(cy_stc_ble_conn_handle_t *)eventParam).bdHandle);
pk.fixedPassKey = 123456;
pk.isFixed = CY_BLE_GAP_PASSKEY_FIXED;
pk.bdHandle = appConnHandle.bdHandle;
apiResult = Cy_BLE_GAP_FixAuthPassKey(&pk);
if(apiResult != CY_BLE_SUCCESS)
DBG_PRINTF("Cy_BLE_GAP_FixAuthPassKey API Error: 0x%x \r\n", apiResult);
but the funtion Cy_BLE_GAP_FixAuthPassKey return an error, in particular :
Cy_BLE_GAP_FixAuthPassKey API Error: 0x16ffff
I share my code .
Lucia
Hi @l_diserio
Thanks & Regards
Pratiksha V
