I had created project attached below using PSoC creator(PSoCCreatorSetup_4.2_b574) and it is working fine, but now I have updated to PSoC creator(PSoCCreatorSetup_4.2_es100_b641) and simply built the project and programmed PSoC 6 BLE (CY8CKIT-062-BLE)
with the ".hex" file. Now its not working, even UART is also not working , I checked using both methods by replacing
and without replacing files when window for updated configuration files popped. Hardware remains same for both the cases.
"I tested your project. It's fine about UART printing function.
There is no printing just because code execution is halted in init_RTC(). More specifically, the halt is caused by below code snippet:
if(RTC_DateTime.year > CY_RTC_MAX_YEAR) /* If user input 4 digits Year information, set 2 digits Year */
RTC_DateTime.year = RTC_DateTime.year % 100u;
RTC_DateTime.year then becomes 0, and beyond range defined in CY_RTC_IS_YEAR_LONG_VALID(year).
Comment the above code snippet, code can executed smoothly with normal printing function.
Please check your code logic. "
From
FWAN
