PSoC™ 6 Forum Discussions
damac_4222651
First like given
I want to make automatic empty bottle detection system as describe in the link https://instrumentationtools.com/automatic-empty-bottle-detection/
I want to use a microcontroller in place of PLC and also using an encoder to reject object at an accurate position
Which PSoC Board would be suitable for my project?
Bob_Marlowe
Level 10
Level 10
A CY8CKIT-043 PSoC4-M Prototyping kit will be able to perform that job. You will probably need some level shifters to connect to the non-5V environment of the asset. Take care for noise in industrial environment: use shielded signal cables only and connect all shields to a single ground point. When at a later point you want to connect your interface using BLE you may add a PRoC module to the board.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
Thanks Bob
I would order CY8CKIT-043 PSoC4-M Prototyping kit
Which  PRoC module need to interface with the board?
I found this https://www.evelta.com/boards-kits-and-programmers/wireless-development-tools/CYBLE-212020-EVAL?lang...
The PRoC module you mentioned looks fine for your design.
