I use CY8CKIT-064B0S2-4343W to run some examples
in this project "Secure_Blinky_LED_FreeRTOS"
When I execute following command (Secure Boot), I get an error.
Step A & B worked as expected
but,running command "cysecuretools -t cyb06xxa entrance-exam"
or
"cysecuretools -t cyb06xxa -p policy/policy_single_CM0_CM4_swap.json provision-device"
will shows the following error
VTARG is 2.5V and KitProg3 is in DAPLink Mode
我使用CY8CKIT-064B0S2-4343W的範例cysecuretools -t cyb06xxa entrance-exam
步驟A和B都正常,但是C跟D都會跳出 下列的錯誤訊息
P : WARN : Skipping CoreSight discovery for AHB-AP#2 because it is disabled
C : ERROR : Memory transfer fault @ 0xe000ed00-0xe000ed03. Check the log for details Error: Failed processing!
想請問一下要如何才能解決此問題
PSoC 6 MCU
- psoc64
- secure boot
Hi @gryfin_chen :
Could you try again following the guide below?
Please also check the python version.
Colin
Hi @gryfin_chen :
Which version of MTB you're working? MTB 2.4 or MTB 3.0?
I need to check it at the same environment with yours.
Colin
Hi @Qi_Colin
I use MTB3.0 ,and BSP is 4.0
I can release my example below
Gryfin
Hi @gryfin_chen :
Could you help to check whether it's useful following the Re-provisioning After Failure Section?
cysecuretools -t cyb06xxa -p policy/policy_single_CM0_CM4_swap.json re-provision-device –-
erase-boot
I try the sample code provided by you, and I don't meet the same problem on my side.
Colin
Hi @gryfin_chen :
According to your latest log information, it seems that not a same error as last time.
Could you help to run command "cysecuretools -t cyb06xxa entrance-exam" or "cysecuretools -t cyb06xxa -p policy/policy_single_CM0_CM4_swap.json provision-device" and get the log again?
I've run "cysecuretools -t cyb06xx7 -p policy/policy_single_CM0_CM4.json re-provision-device" on CY8CPROTO-064S1-SB EVK and got similar error information with yours.
OTOH, the error information shows that "ERROR : Engineering Sample version of PSoC64 detected, the current version of CySecureTools is incompatible. Please contact Cypress to receive production versions of PSoC64 Silicon." when I run "cysecuretools -t cyb06xx7 -p policy/policy_single_CM0_CM4.json provision-device".
If you got the same feedback, it's an IC version issue.
Please help to check it again.
Colin
Hi @Qi_Colin
It seems that an error occurred when Verifying ASSET_HASH
But it is also can,t update the KEY through Re-provision-device
Gryfin
Hi @gryfin_chen :
Colin
Hi @Qi_Colin
After I use Cyprogrammer to clear SYS_AP, SYS_M0
Re-run the command again using your suggestion, confirm VTag = 2.5V
Until the Re-provision-device command clears all sectors
finally succeeded....
Although the key reason is not known,but still very grateful for the help!!
Gryfin
