horiamodran
First like received 5 replies posted 5 questions asked
I am trying to use this example https://github.com/Infineon/mtb-example-psoc6-bmi160-motion-sensor-freertos#operation for CY8CKIT-062-WIFI-BT (which is on supported devices list).
As described, I changed the INTERFACE_USED and BMI160_INTERRUPT_CHANNEL values in motion_task.h, but when i program the device and connect through Putty it is blocking after printing the first line (screenshot attached).
Any idea about what could be the issue?
Arpit_S
100 solutions authored 250 sign-ins 10 likes given
Hi @horiamodran
I tried running the Code example on ModusToolbox 3.0.0 and I was able to run it successfully. Please find attached screenshot for your reference.
Please make sure that you are using ModusToolbox 3.0.0. You can download the same from here
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.modustoolbox?_ga=2.133214798.1555881233.166...
Thanks!
Kind regards
Arpit Srivastav
Arpit_S
Hi @horiamodran
Can you please tell if you are using CY8CKIT-028-EPD or CY8CKIT-028-TFT
Kind regards
Arpit Srivastav
Arpit_S
Hi @horiamodran
Thanks!
Kind regards
Arpit Srivastav
