Hi Community,
I want to test the QSPI interface of the CY8CPROTO-062-4343W Kit. I want to use one PSoC 62 as a master and one as a slave.
I want the sample project of PSoC 62 in QSPI Master & SIave mode.
Could someone provide me with some information about this, please?
Hi @Bhavin_D ,
Please refer to the below documents and code examples and let us know if this helps.
https://github.com/Infineon/mtb-example-psoc6-qspi-readwrite
https://github.com/Infineon/mtb-example-psoc6-qspi-xip
Hi @Alakananda_BG ,
I have already gone through the documents and examples you shared. But I want to use QSPI in master & slave mode, which is missing.
Bhavin
Hi @Bhavin_D ,
Currently, we do not have a code example for QSPI in master & slave mode.
Hi @Alakananda_BG ,
Could you please direct me on how to use QSPI as SPI master/slave? Because I couldn't find the HAL APIs of QSPI to use as master/slave.
Hi @Alakananda_BG,
Ok. So this QSPI could be used only for memory communication not for anything else. Is this correct understanding?
