For some reason my PSoC 6 BLE only operates correctly 1 time after it has been programmed.
If i was to turn it off then turn it back on it again it won't work as it's supposed to, i would have to reprogram it every time i wanted to use it so it would work correctly.
any ideas what's wrong?
- problems
Hello Edwin,
1. Are you using one of our development boards or you custom board ?
2. What is your application and what exactly is failing ? Is it the complete board functionality or certain features in your design ?
3. How are you powering the device and how are you programming the device ?
Vasanth
Yes, i am using the development board CY8CKIT-062-BLE.
My application for the PSoC is the bring for an autonomous RC car, implementing the Bluetooth function as the initialization for its driving system.
I had the RC car working for several months before but for some reason it no longer works like it used to, I was able to turn off the PSoC, then when i had to turn it back on right away it would work immediately as intended to.
When i initially program the PSoC 6 using PSoC creator all functionality works as they are supposed to, but for some reason when I disconnect power to the PSoC, and then turn it back on the Bluetooth function that i have no longer responds as it should.
The Bluetooth, when detected is supposed to change LED color depending on alert level selected.
The PSoc is powered by a battery via External power supply connector.
Edwin
Hi Edwin,
To isolate whether the issue lies in board or the application, please program a blinky project on your board and see whether the LED blinks after power off and on.
If the blinky project works fine, please attach a simple project that recreates your issue so that we can test it at our side.
Ganesh
