PSoC™ 6 Forum Discussions
MiS_4610836
5 questions asked First reply posted First question asked
Hi, i can't find full list of all PSoC 6 MCU's
I find this side:
https://www.cypress.com/search/psg/114026#/?_facetShow=ss_pmain_core,ss_psecondary_core,fs_pmax_oper...
But here there are olny PSOC6ABLE mcu's(CY8C6xx6 and CY8C6xx7) I need list of PSOC6A2M and PSOC6A512K(CY8C6xx5, CY8C6xx8, CY8C6xxA) devices.
Where I can find that list?
Also I can find somewhere list of Silicon ID's all PSoC 6 devices?
DheerajK_81
You are right. I have asked the internal team to update the product selector guide to list all devices. However, I don't think there's any webpage that lists the Silicon IDs. You can find the Silicon IDs of PSoC6 devices in the PSoC Programmer installation directory at the path: "C:\Program Files (x86)\Cypress\Programmer\Devices" in the files "CY8C60xx.dat", "CY8C61xx.dat", "CY8C62xx.dat" and "CY8C63xx.dat".
Note that this doesn't have PSoC6 2M and some other newer devices which are supported as part of Cypress Programmer. The way it works now in Cypress Programmer is, we read the Silicon ID from the SFlash address rather than from a file.
You could do something like this in your code to get the IDs. Not sure what your requirement is, but providing a small snippet of that if it helps:
   uint8_t rev_id = CY_GET_REG8(SFLASH_BASE + 1);
   uint16_t silicon_id = CY_GET_REG16(SFLASH_BASE + 2);
   uint16_t family_id = CY_GET_REG16(SFLASH_BASE + 0x0C);
   printf("Revision ID: 0x0%X \r\n", rev_id);
   printf("Silicon revision: 0x0%X\r\n", silicon_id);
   printf("Silicon revision: 0x0%X\r\n", family_id);
Check SFlash PDL documentation for more information.
Dheeraj
MiS_4610836
I found datasheets with mcu's list and some ID in psoc creator, but I need list all psoc 6 silicon id numbers.
Its possible to get it from somewhere?
DheerajK_81
Dheeraj
