harijith1
Hi sir,
I am working on psoc6 . It is supporting i2c multi master.  First I am configured in slave mode and master send to data to slave by using cyhal_i2c_master_write(). and I am trying read data from slave by using slave function cyhal_i2c_slave_read(). During debugging time I am getting timeout error. How to solve this issues ? how to configure properly?
Len_CONSULTRON
Level 9
Level 9
@harijith1 ,
I'm assuming you have two I2C ports configured on your PSoC6.  One as I2C master and the other as I2C slave.
I'm also assuming the I2C lines (SCLK and SDA) for both ports are connected together by some connection (wired?).
Len
Yes correct. My psoc 6 act as master, Nvme drives are connected to psoc6 so
drives act as slave. Between them two pins are configured Scl and Sda.
@harijith1 ,
Are you willing to share your non-functioning project with the forum?  Many times others can reproduce your issue and review the SW to determine root cause.
Len
