PhilD
10 sign-ins First like received First solution authored
I tried to get segger systemview running to trace the freertos tasks.
The way freertos is used in Modustoolbox is so fundamently different that I was not able to get it running.
Can you support a project using freertos and has everthing implemented so that segger systemview works?
Thank you and best regards
Phil
Rakshith
Hi Phil,
I am checking internally if we have an example project which supports SystemView. I am not sure if this was tested on our device.
Meanwhile, can you please let me know the steps that you have followed to configure FreeRTOS to enable SystemView? Did you manually make the changes or did you apply the v10 patch?
Thanks and Regards,
Rakshith M B
PhilD
Hi Rakshith,
thanks for taking care of this. I have followed the instructions in the SystemView User Guide.
SystemView comes with a FreeRTOS config file and several other files that need to be implemented in the project.
I applied the patch.
Philipp
Andreas_Heder
50 sign-ins 10 questions asked 10 replies posted
Hey,
are there any solutions here? Examples?
best regards
Andi
