PSoC™ 6 Forum Discussions
ViCh_2676191
5 replies posted First reply posted First question asked
I would like to do a fixed stack OTA upgrade on a PSoC 6. I found AN97060 which explains about fixed stack OTA on PSoC 4. Digging around, I also found example projects on PSoC creator 4.2  (BLE_OTA_FixedStack_Bootloader) that does the same on a PSoC 4.
But, PSoC 6 examples only contains CE216767 (separate stack for bootloader and appklication) and upgradable stack projects. I couldnt locate any starter code for Fixed Stack OTA for PSoC 6 where the application and the bootloader shares the same BLE component. Is it possible to do Fixed Stack OTA on PSoC 6, if so, is there any starter code that I could utilize.
Thank You.
Vimal
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Apologies for the delay. There is no separate fixed stack code example for PSoC 6 MCU. In CE220960 - PSoC 6 BLE Upgradable Stack Bootloader, BLE stack is shared between App1 and App2, ie., stack application and user application. Please use this code example to get started. Hope this helps.
GeonaP_26
