PSoC™ 6 Forum Discussions
theaaronm
10 sign-ins 5 replies posted 5 questions asked
I am using the B revision of the pioneer kit and therefore need to use PDL 3.0.1. Whenever I try to generate the ADC with this PDL I am unable to do so. How can I configure it to work with this PDL?
Vasanth
Could you please share more details on the exact error you are facing ? Could you please let us know your ADC configuration code and the problem you are facing?
Vasanth
I am following along with the getting started with the PSoC 6 MCU videos and am on video 2-6 Getting started with analog features. The error I am getting is "The Peripheral Driver Library (PDL) driver is incompatible with the Scan_ADC_v3_10 component used in the design, please install the latest PDL." I believe this is because I am using Revision B of the Pioneer kit and therefore had to use a specific PDL, but I do not know how to configure the ADC for the correct PDL.
