Communication
100 replies posted First solution authored 250 sign-ins
Hi everybody!
Currently, I am implementing a program to consider the conditions to activate the engine as below!
However, my program does not study the condition of the humidity function nor the temperature function!. Does anyone know why or not. When I run the program even though the temperature and humidity are right, the motor still spins!
Thanks!
PandaS
100 solutions authored 5 likes given 250 sign-ins
Hi @Communication ,
Could you please try entering the debug mode and putting a breakpoint at the humidity and temperature conditions.
Check if the program counter reached there or not.
Warm regards,
Sobhit
PandaS
Hi @Communication ,
Warm regards,
Sobhit
How do I do it?
I do not understand what you mean?
PandaS
Hi @Communication ,
To debug the application, please click on the debug with Miniprog3/4 below:
Use the step over or step into tools to move through the code.
And double click of the Blue bar to create a breakpoint:
Warm regards,
Sobhit
Thanks!
