AnCi_2234676
Level 4
Level 4
10 replies posted 5 replies posted 10 questions asked
I am trying to write an application where the BLE component would run in single core mode on the cm0+ core. For now, nothing runs on the cm4. After generating the application, if I look at BLE_config.c, I see everything disabled (CY_BLE_MODE_PROFILE macro set to 0) so I can't access the component configuration.
What am I doing wrong?
NidhinM_71
10 likes received First like received First like given
PSoC Creator shows the macro definitions in that file from Cortex-M4 context. That's why the contents of that file look disabled. You can simply ignore that and start writing code on CM0+. All component macros, APIs and data-types will be available on CM0+.
Nidhin
NidhinM_71
Nidhin
