Hi all, after some hours of trial and error I found a solution to make the Voice recorder example CE22221 working with this hardware.
The pictures tell all:
That's all!
Thank you very much - I have been trying to get this set up working since last week. I would not have guessed the problem is with the clock!
I'm trying to get this working. So far I see that CM0P gets a timeout configuring the PLL but have not resolved it.
Unfortunately, your pictures are not showing up in the forum now, so I cannot see how you got it working.
Thank you for posting that one.
Please post the other two pages of the clock configuration. I'm still stuck with a timeout on the PLL.
Oh, I just realized I was trying to use ECO instead of BLE ECO. Works much better if the selected ECO has a crystal attached to it.
Now all ok ??
Now it works!
Thank you for sharing the details.
I'm copying in the E-Ink support from one of the other examples and moving forward.
