I have the PSoC 6 BLE Pioneer Kit CY8CKIT-062-BLE and am following along with the PSoC 6 101 Video Series. I am able to get the project generated successfully and get a "successfully programmed" message after programming in the output window, but have no LED response on my board and am unsure if it is even working.
PSoC 6 MCU
This may not apply to you, but in the PSoC 6-BLE Pioneer Kit (CY8CKIT-062-BLE) web page
https://www.cypress.com/documentation/development-kitsboards/psoc-6-ble-pioneer-kit-cy8ckit-062-ble
There is the following table,
If the Kit Revision of your board is *A or *B, you need to use PDL 3.0.1.
If the Kit Revision of your board is **, I'm sorry but you are out of luck...
To specify the PDL revision, from PSoC Creator Menu
Project > Build Settings
And in the Peripheral Driver Library, select Custom and specify PDL\3.0.1
BTW, to get PDL 3.0.1, please access the following URL
moto
Hi @theaaronm ,
I see that in the Lesson1-3: Hello World of PSoC 6 101 Video Series, there has been used 3 different methods to demonstrate the working of the project. Can you please let us know which method is failing for you to output as a blinking LED?
Also, can you please let us know if you have seen any warning while programming the CY8CKIT-062-BLE device for the first time or the device programmed without warnings?
Please let us know your comments regarding the above.
Aashita
Hi Aashita,
Thank you for your reply, I have tried the first two methods from the video. The first method is using the built in PWM function and the second using the GPIO write function with a delays.
Thank you,
Aaron
moto
I have Rev B of the kit and that fixed my issues!
Thank you,
Aaron
