HI Cypress Team,
In my custom board which uses PSOC62 BGA part: CY8C624ABZI-S2D44, we are facing issue in configuring the pull-down.
Can you please let me know your feedback on below:
1) What is the Strong Pull down value for PSOC62?
2) What is the Weak pull down value for PSOC62?
3) I wanted to configure my IO (P12.0) as Input with Weak pull-down, Please let us know the proper procedure to configure it correctly.
4) The same design is working fine on PSOC4 based custom board.
- psoc62
BiMa,
Excellent question!
I've tried to look up the information in the part's datasheet. The best I could come up with is a pull-down resistance spec for the GPIO of 3.5kΩ min, 5.6kΩ typ and 8.5kΩ max. I assume this is the strong pull-down. I could not find the "weak" resistance spec.
Len
BiMa,
Excellent question!
Len
