aliissa02
100 sign-ins 50 replies posted 5 likes given
I am trying to display the unique ID of my PSOC 6 device in the terminal but its not working. I have attached the project. Can anyone help please?
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @aliissa02 ,
I found the cause of the issue as that you are using the wrong API for getting the unique ID.
The one to use is Cy_SysLib_GetUniqueId() .
I have modified your code and attached the working version here.
Note : I changed the UART Tx Pin to P5_1 from P11_1.
Hope this helps.
Warm Regards
Alen
AlenAn14
Hi @aliissa02 ,
Hope this helps.
Warm Regards
Alen
