I found that when I remove a global variable in the project code, eeprom could not read or write normally. The project code is in the attachment. The global variable is NotifyData[NotifyDataLen] in bleTask.c.Thank you.
You can not put EEPROM R/W operation and BLE stack host controller on same core without linker scripts modification.
I have tried to modified CE216767, involving EEPROM on cm4 and stack running on cm0+ with spliting working flash space into two separate parts for cm0+ and cm4 through linker scripts respectively.
It can work finely.
The attached project has building error on PDL3.0.4 like below. Can you double check?
Hi, i have EmEeprom issues too.
My PDL version is V3.1.0. and my code works normally,
but after i added DFU to my projects, the eeprom write never return back.
So i have to move my code to CM0p and disable CM4. Works normally.
But i want to run my code on CM4.
Because my CY8CKIT not support PDL 3.1.0, so i can not give a project to show my situation.
the attachment are my dfu ld files.
Please give some advices, or give me a ble dfu application(CE216767) with em_eeprom, thanks.
It can work finely.
