Hello, I'm trying to use PSoC 62s4 pioneer kit with PSoC creator, and it isn't work. I installed all programs, and I have made all the update, but nothing.
By device manger, seems that the port is ok.
And the "Program" function is working very slow!!!
PSoC 6 MCU
Hi @biz0noff
Creating the project using the method you have mentioned will select a default MPN for the project which will be different from MPN CY8C6244LQI-S4D92 that you are using. You can view the MPN selected for your project in the Workspace explorer as can be seen in the image below.
The device that you are using is supported only in Modudtoolbox IDE. Please refer to the links below that will help you get started with Modustoolbox: Getting started with Modustoolbox
In case you want to stick to PSoC Creator you can consider using CY8CKIT-062-WIFI-BT Pioneer kit which has CY8C6247BZI-D54 device which is directly supported by PSoC Creator.
Best Regards
Ekta
Hello @biz0noff
Since you are using the CY8CKIT-62S4 evaluation board the device MPN you are using is CY8C6244LQI-S4D92 device. I could not find the device MPN being supported in PSoC Creator.
Could you please check and let me know the device MPN you have selected for the PSoC Creator project?
I would recommend you use Modustoolbox IDE for creating your application. Modustoolbox directly provides you option to select the CY8CKIT-062S4 when creating a project:
Best Regards
Ekta
Hello, I create the project from there
I don't know if it's fine, but, after 3 weeks of trying, nothing.
I want PSoC creator because is easy, and intuitive and more fast for my project.
Hi @biz0noff
Best Regards
Ekta
