Let me be frank. This might sound crazy but this is what it is. I have bought PSOC6 - Wifi - BT kit. My intention in buying this is to know about PSOC6 as well as to learn embedded programming.
I had been exploring from a week or so on this. Just got used to the PSOC creator and the device. But when I wanted to further start working on it. I am not getting what to do. I don't know what to do next.
Can anyone suggest some applications which can be done with PSOC6 with out any external hardware involved ( Apart from the kit contents ). Again note that I wanted to do more coding and know more about the device.
Thanks In Advance.
First of all, thank you for investing your time and money in Cypress products.
The kit you bought CY8CKIT-062-WIFI-BT contains a 2.4-GHz WLAN and Bluetooth functionality module (CYW4343W) connected with PSoC which helps you to develop wifi and Bluetootth applications along with several embedded applications. To get the code examples related to WIFI module present in this kit, please install Modus Toolbox 2.1 in your system.
Modus Toolbox 2.1 is the platform where you can develop your applications related to MCU as well as CYW4343W in a single platform. You can download it from the link below.
https://www.cypress.com/products/modustoolbox-software-environment
After downloading, please go through the Modus Toolbox user guide from the link below.
https://www.cypress.com/file/504361/download
Also, please go through project Creator user guide from the link below. Using this you can explore the lot of code examples related to this kit.
https://www.cypress.com/file/504421/download
You can also refer the Kit guide of this corresponding kit from the lnk below:
Hope the above documentation helps ! Happy Learning !
Ganesh
Ganesh
