我们使用PSOC6外挂nandflash,想通过USB接口连接PC,枚举成USB MAX storage,将设备拷出,
能提供相关的例程或技术文档来实现吗?
BR,
Moon
We have a new code example to show how to setup the USB Mass Storage Device Class with PSoC 6.
This code example uses the internal SRAM to emulate a file system. In your case, you will need to use another type of file system through a NAND flash.
PSoC6通过QSPI接口外挂nandflash?具体是将哪个设备枚举成USB mass storage,是外挂的nandflash?
nandflash,
Is there a NAND flash driver from Cypress that can work with TLC NAND and perform functions like garbage collection, wear leveling, bad block management, ECC check. I would like to use the PSoC in a USB flash drive product.
We only support the hardware layer. It has QSPI and SD host to interface NAND type of memories.
