PSoC™ 6 Forum Discussions
PrGa_4700211
First like given
Hi
I have PSOC6 WiFi-BT Pioneer kit. I see that it comes with a TFT display. Does cypress provide any drivers to interact with that ?
VenkataD_41
PSoC Creator supports using emWin graphical user interace library to be used with PSoC6 family devices. You can enable it from Build settings--> Peripheral Driver library--> ewin --> Core and LCD Drivers.
In case you are using modus, you have to enable emwin library from Library manager--> Libraries--> Board utils--> Middleware
You can get the library guide as well as code example for TFT LCD interface with PSoC 6 from the link below:
https://www.cypress.com/documentation/code-examples/ce223726-psoc-6-tft-display-interface-emwin-grap...
Hope this helps !
Ganesh
VenkataD_41
Hope this helps !
Ganesh
PrGa_4700211
First like given
Hi Ganesh,
Thanks for the reply,
I am not able to see the driver in PDL. Should I make any changes to get that. I have tried with the latest PDL as well.
Please download the latest PDL library from here: https://www.cypress.com/design-guides/peripheral-driver-library-pdl-psoc-creator
The latest is 3.1.2. Once downloaded, point to its directory in the Custom field of the PDL settings. You should now be able to see EmWin.
Let me know your observations.
Dheeraj
PrGa_4700211
First like given
Hi Deeraj,
Now I am able to see the LCD driver. Thanks.
MLP
