Hi
I am using CY8CPROTO-062-4343W PSOC6 WIFI-BT PROTOTYPING KIT.I need to take current time. I had used RTC basic code from project creator in ModusToolbox. After program downloaded successfully I didn't get the current time and while i got tried to change time ,its able to select the the option but i cant enter the timings .what will be the possible issues for that .Could you please help me to sort out the issues. I am attaching the image where I got stuck
Thankyou
ispn:40047:1:0
l1:314:1:0
Hi @SURYASUNDAR,
I tried to program the same code example with the same board(CY8CPROTO-062-4343W) it's working at my end.
Figure 1
Note:- "HH MM SS dd mm yyyy" where HH - hour, MM-minutes, SS-seconds, dd-date, mm-month, and yyyy-year(all separated by a space) should be in a correct format. While typing "HH MM SS dd mm yyyy" in Tera Term it will not be visible in the Tera Term window only after pressing enter key it will be visible.
If it is in the correct format and matches with your laptop date then RTC time gets updated and the correct date and time will get displayed(Figure 1).
Else you get an error as in the below screenshot(Figure 2):
Figure 2
Please let us know did you try to press enter key on your keyboard after typing time and date values?
Warm Regards,
Gautami J
Hi @SURYASUNDAR,
Figure 1
Figure 2
Warm Regards,
Gautami J
