Hello everyone,
I work on a project with CYBLE-416045-02 and FreeRTOS. Sometimes i have an error when BLE Task start, my stack go to ON state and advertisement start.
But for my advertisement, i have an error code : 1600FF.
I would like to know if you have meet this kind of problem ?
Max
Hi @Max
Please can you refer the code examples for freeRTOS :
1)CE218137 – PSoC 6 MCU with BLE Connectivity: BLE with Proximity(RTOS)
2)CE218138 – PSoC 6 MCU with BLE Connectivity: BLE Thermometer (RTOS)
Please let me know if this helps if not can you share your project where you are facing this issue so that we can reproduce it at our end.
Thanks & Regards
Pratiksha V
Hi Pratiksha V,
I have start my project with : 2)CE218138 – PSoC 6 MCU with BLE Connectivity: BLE Thermometer (RTOS)
After take this example, i modified it to develop my own project.
I know that the problem come from when my Stack is ON, when this function is executed :
bleApiResult = Cy_BLE_GAPP_StartAdvertisement(
CY_BLE_ADVERTISING_FAST,
CY_BLE_PERIPHERAL_CONFIGURATION_0_INDEX);
Because my code error 1600FF come from bleApiResult :
if(bleApiResult == CY_BLE_SUCCESS )
Task_DebugPrintf("Success : BLE - Advertisement API", 0u);
else
Task_DebugPrintf("Failure! : BLE - Advertisement API, "\
"Error code:", bleApiResult);
So i check the Cy_BLE_GAPP_StartAdvertisement function to understand return information where the type is : cy_en_ble_api_result_t
So with that information i arrive into a file named : cy_ble_stack.h where different error are defined but i don't understand which error my error code correspond.
Hi @Max
I am not able to reproduce this issue at my end .please can you share your project so that we can understand the issue better.
Thanks & Regards
Pratiksha V
Hello PratikshaV,
Thanks for you help,
I check if i can send you more informations about the project,
But for you this error code not correspond in something in particular ? (in BLE library ?)
Max
hi PratikshaV,
Thanks for this information,
I will look at this.
Max
@Max You should just be able to press F3 on the function , then it shows the return type is cy_en_ble_api_result_t , press F3 on that and it will show all the values. If this does not work (and it probably does not) it's because your Eclipse is not setup right. You need to add the directories where the header file cy_ble_stack.h resides to the project settings. It is most likely "mtb-shared" This is one of the maddening things about Modus TB, in the default config, the compiler will find *.h files through the makefile but the IDE has no idea.
Hello Panometric,
I use as IDE Psoc Creator 4.4 so i can't check exactly like that.
