PSOC6 Debugger not detected
Hemanth1
First like given 50 sign-ins 5 replies posted
I have successfully programmed and unprogrammed PSoC demos on the CY8CPROTO-062-4343W boards but once I program an Wifi_Demo the board is bricked. The board runs the firmware but cannot be reprogrammed. I have tried this on 5 different boards with the same results. This  discussed the same problem without providing a solution. BTW I have updated the adapter firmware tried the Cypress programmer as well.
Any help will be appreciated since I have had to order 5 new boards.
Log Error:
1. Error: DAP 'psoc6.cpu' initialization failed (check connection, power, transport, DAP is enabled etc.)
2. Warn : Failed to power down Debug Domains.
3.Error: Failed to connect to the target device.
The firmware is disabling the SWJ pins and as a result, we are not able to program the device again. We will get in touch with Atmosphere IoT to rectify this issue.
Here I have attached Screenshot of this error.
Thank you for bringing this to our notice!
You will be contacted by a Cypress, an Infineon Technologies Company, representative regarding the replacement of your kit.
Hope this helps,
Thanks and Regards,
Hemanth
Aditi_B
500 replies posted 5 questions asked 250 replies posted
You can put the kitprog3 to either in bulk or hid mode to program. You can use fw-loader to update the kitprog if required.
https://github.com/Infineon/Firmware-loader
Aditi
Aditi_B
What happens if you do not use any external programmer? PSoC boards support kitprog. Have you used it to program the applications?
Aditi
Aditi_B
Aditi
