Hello All.
I am trying to program a PSOC6 BLE Prototyping Kit (CY8CPROTO-063-BLE).
Today, when I was trying to write the updated program,core M0 and M4 are no longer recognized. They were recognized the day before.Is there any possible cause for this?
The first picture is the problem this time, I want it to appear as the second picture. Yesterday it looked like the second one.
thank you for finishing.
hiroki
PSoC 6 MCU
- psoc6
Hello @DheerajK_8
Yesterday, Downgrading is not a problem.So i was a downgrade it to kitProg 2.
then it's been good from there.
Thanks for all your help.
Hiroki
Hello @hiroki ,
Can you please check the mode the KitProg3 is in? Refer to the KitProg3 User Guide to understand the different modes and their respective status LED indications. I believe you may have pressed your SW3 mode switch and put your KitProg3 into DAPLink. You can press it again and get it back to BULK mode.
Let me know if this works for you.
Dheeraj
thanks for replying,@DheerajK_81.
I had read the KitProg3 User Guide.
When I turned it on today, it was recognized for some reason.
I won't reproduce it now.
I pressed the sw3, but the Stutas LED just lights up amber.
Could it be that the board is broken ?
Hiroki
Hello @hiroki ,
You could try doing a couple of things before deeming it broken like:
1) Connect the USB cable to a different USB port
2) Opening device manager to see how it is enumerating
You mentioned that when you turned it on today, it recognized it. Does that mean your issue is fixed?
Dheeraj
Hello @DheerajK_8
Hiroki
Hello @DheerajK_81
1) Connect the USB cable to a different USB port →There was no change.
2) Opening device manager to see how it is enumerating.→It is enumerated like KitProg3 CMSIS-DAP
Yes.But it will reproduce over time.
I did some troubleshooting, but it didn't change.
Hiroki
