PSoC™ 6 Forum Discussions
Under windows 10, PSOC Creator 4.2, I create a new project, when building, the fellow erro is always:
build error - prj.M0120:build error:未将对象引用设置到对象的实例
Roy_Liu
1000 replies posted 500 solutions authored 5 questions asked
Please check if the method mentioned in the threads below can help you out, if not you may try to re-install your PSoC Creator 4.2.
PSoC Creater 4.2 Startup Error - Newbie
Build error: Object reference not set to an instance of an object.
Roy
Roy Liu
Roy_Liu
Roy
Roy Liu
