aliissa02
Level 4
Level 4
100 sign-ins 50 replies posted 5 likes given
I am using a PSOC 6 prototyping board (CY8CPROTO-063-BLE) and I would like to add 5 extrenal LEDs and 2 switches. Can I use the pins P10[0], P10[1], P10[2], P10[3] , P10[4] for the LEDs and  P10[5], P10[6] for the switches?
Thank you
MiNe_85951
Level 7
Level 7
Distributor - TED (Japan)
50 likes received 500 replies posted 50 solutions authored
Those pins (P10[0:6]) can be used as GPIO without any problem.
CY8CPROTO-063-BLE schematic URL
https://www.infineon.com/dgdl/Infineon-CY8CPROTO-063-BLE_Schematic-PCBDesignData-v01_00-EN.pdf?fileI...
CYBLE-416045-02 Datasheet URL
https://www.infineon.com/dgdl/Infineon-CYBLE-416045-02-DataSheet-v02_00-EN.pdf?fileId=8ac78c8c7d0d8d...
Table 4. Digital Peripheral Capabilities
Note that general purpose GPIO can be assigned to almost any pin, but special functions(UART, SPI, I2C, TCPWM and so on) can only be assigned to dedicated pins.
MiNe_85951
Level 7
Level 7
Thank you very much!
