horace
Distributor - Burnon(GC)
How to solve this problem?Thanks
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @horace ,
From the error message you have provided, it seems like the Application 1 (which is the downloadable) is set for the wrong part number. Can you please confirm that this firmware is set for CY8C6347BZI-BLD53 device same as that of Application 0.
Can you refer this thread and use the reference code that is provided in the same.
https://community.infineon.com/t5/PSoC-6/PSOC-6-DFU/m-p/264102
Let me know if you are having any difficulty with the same.
Note: In this sample code, for the .cyacd2 file generated for the Downloadable application, please rename it from "Downloadable.cyacd2" to "Downloadable_1.cyacd2" (the '_1' in the name is necessary for the Bootloader host tool to recognize it as image 1)
Please make sure you are following the step 2 in Operations Section mentioned in the CE2103903 Document
Alen
AlenAn14
Hi @horace ,
Can you please let me know the exact part number (MPN) of the PSoC 6 device and PSoC Creator version you are using for this project?
Alen
horace
CY8C6347BZI-BLD53, PSOC creator 4.4
AlenAn14
Hi @horace ,
Has the issues been resolved?
Was it due to the incorrect part number selected for application 1 (downloadable).
Alen
horace
The problem hasn't been solved yet
AlenAn14
Hi @horace ,
Alen
