Hello All!
Is there a document that states the benchmark tests for the floating point operations on a PSOC 6 (the 150MHz M4 core)? I'm looking for things like execution time for floating point operations add/sub/mult/divide/square root.
We do not have any document with benchmarking tests for the FPU unit. You can only notice the significant difference of having an FPU unit when you run for example DSP operations which will need many floating point operations. Attached is an interesting white paper which documents the performance improvement with the FPU on the CM4 core when running DSP operations.
Dheeraj
Dheeraj
