PSoC™ 6 Forum Discussions
Does PSOC 6 have an EMIF interface available for external memory?
DaKo_463136
10 likes received 10 likes given 5 likes given
Have a look at these two blog posts, whether they fulfill your expectations
PSoC 6 Serial Memory Interface (SMIF) Part 1
PSoC 6 Serial Memory Interface (SMIF) Part 2
David
DaKo_463136
David
Is there a component for parallel connected memory interface?
No, we do not have a parallel memory interface component.
There will be a LCD controller component in future, which will have a parallel interface to external memory. However, this memory cannot be used as executable or extended RAM.
If you want to use the memory as executable or extended RAM, then you will need to use the SMIF component.
