PSOC 6 Crypto
Francesco
I am able to perform the following transactions in order with success:
Cy_Crypto_Sha_Run(), Cy_Crypto_Rsa_Proc(), Cy_Crypto_Aes_Init()
If I change the order it does not work anymore:
Cy_Crypto_Aes_Init(), Cy_Crypto_Sha_Run(), Cy_Crypto_Rsa_Proc()
Why I am unable to perform a Sha_Run()/Rsa_Proc() if i perform a Aes_init() before?
Thank you,
Francesco
Pushyanth_K
100 sign-ins 10 solutions authored 50 replies posted
HI @Francesco ,
If you call the functions in the order:
1.Cy_Crypto_Aes_Init()
2.Cy_Crypto_Rsa_Proc()
3.Cy_Crypto_Aes_Ecb_Run()
The Cy_Crypto_Rsa_Proc() overwrites the key placed in the Crypto Memory buffer address. In the attached image, you can see that the Crypto memory buffer is cleared (Using Cy_Crypto_Core_Memset()). So if you call the Cy_Crypto_Aes_Ecb_Run() after Rsa_Proc(), then the encryption of AES will not happen with the actual key. But it will not affect the Rsa_Proc(). Can you confirm whether Rsa_Proc() or Aes_Ecb() that is getting affected?
Gautami_12
50 likes received 100 solutions authored 250 replies posted
Hi @Francesco ,
The Init functions are only to initialize the different techniques offered by the respective crypto block. For example, Cy_Crypto_Aes_Init() is needed for AES operations. If you want to use a different encryption scheme for AES, then you need to call  Cy_Crypto_Aes_Init()You must initialize this technique again after using any other encryption technique.
Please refer to the  PDL and try to implement the project accordingly.
Warm Regards,
Gautami J
Hello Gautami,
The issue is I am able to perform a RSA_PROC() but it doesn't work
anymore if I perform an AES_INIT() before. Any thoughts on how the
AES_INIT() may impact the RSA_PROC()?
Thank you,
Francesco
Francesco Giordano, Eng.
Hardware & Firmware Developer at Hexoskin
+1 888 887 2044 | www.hexoskin.com
Montréal: 5800, rue Saint-Denis, Suite 601, Montréal (Québec) H2S 3L5
The content of this email, its attachments, linked documents, and
referred documents, is confidential.
100+ Research Publications with Hexoskin Data
Discover Hexoskin Connected Health Platform
Monitoring Solutions to track COVID-19 Symptoms Remotely & Continuously
Visit the Hexoskin Support Community
Pushyanth_K
HI @Francesco ,
Pushyanth_K
Please let us know if your query was resolved.
We will lock the thread in 3 days.
If your problem is not resolved, please create a new thread and we will be happy to help.
Pushyanth
